Here my 2 Cdn cents, not worth a lot these days. My Grandfather got this SW6(1953) in 55'. No factory hyd's, so he had a pto mounted char-lyn setup. Any time needed to use pto, the pto pump had to come off. Sometime in the 70's my Dad put a hyd pump off the front of the engine. It worked till I had enough of the worn out system 2 years ago. The ram is very slow, the hyd pump leaked more oil than it pumped. So I redid the whole system. The drive shaft has been on the front of the engine for 45 yrs without any issues, no u joint, no love joy couple etc. I had local machine shop make up a new shaft, new pin for the crank shaft. I cut up the mounting plates.
This post was edited by Redturbo at 20:20:25 03/17/15.
Today's Featured Article - Tuning Up Your Tractor: The Battery - by Curtis Von Fange. Buried somewhere beneath the sheetmetal, under the gas tank, or stuffed in front of the radiator is the battery. This elusive and neglected component of the tractor is the hardest to get to when it is dead and in need of a jump. But usually, the storage battery is a storehouse of electrical energy waiting to be released a the flick of a switch. A few maintenance tips and periodic cleaning will keep it charged for the duration of its life span. The battery is made up of a number of lead bas
... [Read Article]
Latest Ad:
[More Ads]
