Posted by Drew W. on March 16, 2015 at 19:02:42 from (108.193.52.245):
In Reply to: Hydraulics for an I-4? posted by rustyfarmall on March 14, 2015 at 10:37:26:
I was thinking that would be the easiest and most serviceable route to take. Could I use the 5/16" set screws in the crank snout as shear pins for a shaft coupling to go to the pump or should I put a shear pin out on the coupling going to the pump itself?
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
