The PTO shaft universal joints will be fine with the offset PTO. You don't need anything special. That is as long as none of the mounting brackets interfere with the shaft. Mowing 33 acres of trees set on 10 ft centers is gonna take a long time. I mow 2 1/2 acres of trees set on 12 ft centers using a 5 ft Woods mower. It takes me about an hour to do it running in second gear. I do have to contend with some hillside terrain and rock out croppings.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
