Get the correct ones from CaseIH and be successful in your rebuild and overhaul. The upper one is p/n 356782R91 or 361086R91 which are optional to each other, the lower gasket is p/n 356799r1. There is also an oil seal required p/n 356784R91 which is noted as part of the valve body. You also need (2) 350667R91 O-rings where the manifold tubes attach to the valve body. You most likely have two issues you are dealing with which are size and cross section shape of the O-rings. Good luck, Hal.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
