I know what I would do . Take the two plugs out that go to cylinder. Use air pressure on inlet side. Operate valve and see which outlet air comes out I each direction. Then pull end cap off bottom and just possibly there is a plug in there to remove and then retest with air to see if air will go on through in one direction of handle pull. Will have to plug the effected outlet in that test. May or may not be a plug there and might even be a relief valve. So many different valves.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
