Everything looks the same in your picture, as this tractor. However, the spring is in place of the clamp for the cable, and another bracket was made for the cable.
Thanks for the advice on how long to activate the glow plug button. We were only holding in for about 30 seconds. But sitting in the shop last night, without heat on, it did start. We had 14 degrees overnight too.
As far as testing the glow plugs, I had the charger set on 2 amps, and held long enough to see some smoke coming off the glow plugs.
Does the glow plug button pop right back out, when you release it, or does it slowly come back out. This one comes out slowly, and when pushing it in, you need to push on it, as there is some resistance.
you also mentioned the timing wasn't quite right on your injector. Did you take the cover off, and reset, or did you do it running, to tweak it?
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
