I am a cheap skate. I would start with the oil pump. Remove the bottom cover of the pump. The gears will have worn grooves into the cover. This increases the clearances and reduces your oil pressure. Put sandpaper on a smooth level surface and set the plate or the sandpaper. Lightly push down on the plate and rotate it in both circular and linear motions until it is smooth. Re-install the plate on the pump. As long as the pump is moving enough oil to the moving engine parts, you should be ok. If pressure improves, you should be good until you have the time to rebuild the engine. SDE
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
