most likely not as different engines. have you checked your oil pressure with a master gauge?, first priority. low oil pressure can be from all worn engine brgs. cams brgs, rod brgs, mains. you need to plastiguage the rods and mains. if you are getting readings over up in the .004-.006 and up you definitely have wear issues. even the oil pump can be worn. crank needs to be checked for out of roundness too. also rods checked for the same, may need resizing. all depends what you are doing with the tractor as they will run forever also even if the oil pressure is not top notch. but have to know what psi you have in the engine. just throwing rod brgs at it wont make much difference.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
