For not picking it up, sounds like maybe the relief valve is low. Best way to check that is with a pressure gauge to see if it's set as high as the one that will pick up more weight.
If I'm not mistaken, that block is a "pilot operated check valve", meaning if you pressure it one way, it opens the return on the other side so the flow will return. Meant to help lock an implement in position and not leak down even if the main valve leaks a little.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
