Re: H Tranny Input Shaft Bearing Replacement
Posted by Oregon Tractor Jack on December 27, 2014 at 11:11:19 from (50.137.138.152):
In Reply to: H Tranny Input Shaft Bearing Replacement posted by Oregon Tractor Jack on December 25, 2014 at 14:38:56:
Is the pilot bearing pressed on the main shaft? I have been trying to get it off and it won't budge.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
