Maybe I confused you when I mentioned the pin in another post. Most times the reason it needs removed is for adjustable pulley replacement. See you have a hex nut that needs removed to slide hub off to replace bearings or seals. Some just have a nut with two flats like in picture. If your hub won't slide of after the hex nut removal, sometimes if bearings get bad enough to spin on the shaft it can be difficult to slide the hub off. Picture is a housing with the hub slide off. Also the pin location if you ever need to replace the adjustable pulley. Had this one apart to get the adjustable pulley for use on another one. Bearing and bearing spacer needs removed from hub before driving pin out. Impeller wasn't the best shape on this one also.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
