You need to remove the bolts from the end of the pump and pull the piece off that the bolts are holding on. You can then more easily access the large nut which will have to be removed before the hub will pull off the shaft.
There is no pin on the generator pulley that needs to be removed. The pin you see on the large pulley is actually a screw that locks the movable half of the pulley in place. Do you see the threads behind the pulley? One half of it will screw in and out for loosening and tightening the belt that drives the pump.
This post was edited by Nebraska Kirk at 20:36:22 12/16/14.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
