I say this because hydraulic lift plows do not have a land wheel lever as a general rule, and you use the hydraulic cylinder to set the depth of the plow.
So, you set your depth with the land wheel lever, and then adjust the furrow wheel to cut a level furrow. On the first pass it's a guessing game. You can go a little ways, check your progress, and make adjustments.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
