Re: Re: Re: IH 460 power steering
Posted by mark on January 06, 2001 at 23:50:29 from (4.16.136.182):
In Reply to: Re: Re: IH 460 power steering posted by Norm on January 04, 2001 at 05:13:00:
Just went thru similar problems with a newly-acquired Farmall 560. Power steering and rest of hydraulic system all worked fine until really cold weather hit. Long-term water accumulation in hydraulic fluid simply froze up. Large chunks of ice formed in rear differential; power steering and rear hitch simply would not function. Be cautious about trying to drive the tractor in case there is ice in your differential or anywhere else in the hydraulic system including the power steering. Overnight in heated garage plus magnetic-mount heater on bottom of differential and transmission housings was able to melt ice in hydraulic fluid. (Drained fluid looked like silty glacial runoff due to water contamination.) Drained PTO housing at same time, had similar water contamination. Be prepared for a LOT of oil flow when draining differential! I recommend having at least 3 or 4, empty 5-gallon buckets and lots of oil-dry on the floor BEFORE you open up the drain plugs, and overnight draining is a good idea. IH manual advises replacing hydraulic fluid every year before cold weather, apparently because of this water accumulation problem. Replacement oval filter at IH dealer was about $17, included gasket for cover plate located on right side of transmission housing. PTO takes 2 quarts of hydraulic fluid, remainder of system takes 16 gallons. Main filler opening is triangular plate with 3 bolts, to right of gear shift base. Have not yet restarted tractor or operated hydraulics since fluid change. Will post tomorrow if this does not fix problems.
Home
| Forums
Today's Featured Article -
Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
