Re: 240 throwout bearing
Posted by Bob on November 11, 2014 at 06:23:50 from (64.255.159.192):
In Reply to: 240 throwout bearing posted by pete hall on November 11, 2014 at 05:16:25:
You are using ambiguous terminology, I THINK by "bearing carrier" you must mean "throwout bearing"???
Tap the old TO bearing off of the sleeve and install the new one in it's place.
If I am not guessing correctly, below is a link to the parts catalog. Take a look and post back!
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
