I have Super H 1854 J , just 25 away from yours. Built in early '53. Just out of curiosity is your motor serial number 2126? It will be stamped into the block on a raised casting below # 3 spark plug - above the crank case breather.Are you in Pa.? Thanks, Pat
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
