Yes - you can safely support the front end of the tractor at the clutch housing. Just be sure to securely chock the rear tires so it cannot move while jacking, etc.
The bolster will slide out easily after disconnecting the radiator hoses, removing the steering shaft then removing the bolts thru the side rails. Loosening each of the motor mount bolts a couple turns can be helpful.
Be aware the bolster assembly is VERY heavy and top heavy. For safety use a loader, engine hoist or similar to handle it.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
