Posted by RTR on October 06, 2014 at 15:22:37 from (66.87.152.29):
I have a ceramic ballast resistor that has 4 prongs and is essisentially twice the size as a typical ballast resistor I've used in the past. I happen to have this one on hand and the auto parts store didn't have a 2 prong in stock. Will this one work? Or is it wired differently and for a different application. I'm trying to hook the distributor wire up on a super a.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
