Posted by D Slater on October 05, 2014 at 16:31:36 from (184.14.160.167):
In Reply to: Super c distributor posted by Joshua Rod on October 05, 2014 at 15:41:56:
If it turned okay before the gear change you ended up with no shaft endplay after putting the pin in the replacement gear. Or let the shaft push toward the point plate and mess the weight guard up. Also find them that someone used to long of screw in the condenser or point contact mount and mess the guard or other things under the breaker plate. If you have end play, remove points and the terminal post from the distributor. Then the 2 cap clip screws and one other from the side of the distributor. Lift the breaker plate out then check guard, springs, weights and the weight pins. Shaft can be removed from the body after the drive gear is removed.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
