Posted by Joshua Rod on September 30, 2014 at 18:15:39 from (172.56.22.108):
In Reply to: Farmall C / Super C posted by cubluvn8n on September 30, 2014 at 17:27:38:
Most pieces should interchange with the C, i really don't know if much interchanges with the A. Where is it/you? If you get it and your within a reasonable range i may take what you dont want.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
