Posted by tractornutjd on September 23, 2014 at 03:07:07 from (24.59.84.81):
Hi, I have to go look at the neighbors 484 cab tractor that is leaking oil from the clutch housing split. Does this tractor have a dry clutch? is it leaking oil from the front of the transmission? I have not worked of these before and looking for any input before I start. thank you in advance
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
