Caps are the most common cooling system failure. Look closely, there s a small mushroom like disk (atmospheric valve) on the bottom center, it should be held closed by a very light spring. Its rubber should be in good condition, as should the rubber that seals against the neck flange. The tension spring that applies pressure is also a failure point in that it can rust or corrode away. The atmospheric valve is to allow the cooling system to draw in air as it cools off, this prevents collapsed hoses or components like top tanks. New caps are cheap. Jim
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
