Posted by CDN 400 on August 25, 2014 at 09:02:03 from (206.132.49.249):
In Reply to: Uncles 826 posted by C.R. on August 25, 2014 at 01:45:47:
DeltaRed does the 826 have the start position on the shut off like the 756?I was just wonndering if the cable could be stretched or even moved and not going completely to the start position.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
