Posted by gene bender on August 19, 2014 at 11:31:46 from (67.55.226.121):
In Reply to: Stuck Valve Super A posted by henhawk1969 on August 19, 2014 at 05:48:29:
The valve is stuck open correct. Remove the valve cover then you can use some spay of any kind on the stem. You should be able to gently pry it up go easy DO NOT TAP IT DOWN as there is a little hair type clip on the stem to keep it from dropping down. A little tapping and prying it should come back up. When you get it back up use a rubber type hammer and tap it a little then pry back up after a few times it should free up. That has worked for me on the same head you have. If you cant free it up you will need to remove the head. good luck.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
