It should unless the valve is only doing it part of the time. Like say it is sticking part of the time, but only at a normal running RPM. A situation like that would perhaps give you a normal compression test reading. If a low compression test, put a squirt of oil in the plug hole and then re-do test. If the result is a normal reading after being low, it is a problem with the rings. If it is low after being low it is a problem with valves most likely, but a chance of cracked head or bad head gasket.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
