Spring and fall are usually worst problem around here because there is enough humidity in the air and temp falls in the correct range for freeze up. In the winter air is usually too dry to hold enough water BUT, big exception, if bucking snow or it is snowing out that will put enough moisture in the air to really freeze them even at higher speeds. The heat stove around the muffler and leading into the air cleaner really works good to cure that problem. I see them manifolds with cakes of ice on the outside so you know wht is inside also.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
