Re: am i just asking too much?
Posted by mkirsch on August 07, 2014 at 11:19:19 from (72.45.143.81):
In Reply to: am i just asking too much? posted by ericlb on August 06, 2014 at 13:55:49:
It's not nonsense, and easily provable.
Your fuel line should run a steady solid stream of gas into a bucket, in order to ensure proper fuel flow to the carburetor.
Place an undersized fuel filter on the line. Fuel flow slows to a dribble.
Place a fuel filter designed for pressurized systems on the line. Fuel flow slows to a dribble.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
