a few answers, fuel flow is fine, it does have a 5/16's rubber hose, as it came with it, i never put a inline fuel filter on a gravity feed tractor fuel system, coolant level is checked every time the engine is started,i got in the habit of checking the fluid levels in every machine i use before i start it when i worked in a gravel pit it was company rules and msha's rules too, its hard to get out of the habit now . the carb is the ih style,i replaced it [ but kept the old one] as when i bought the tractor several years ago, the carb had a hairline crack in the top cover it finaly broke, i found another one in a friends barn and thought maybe the mismatched unit just wasnt any good, i had bad luck with a zenith on a ford and wont buy another one, i did check the cap and its vent is open, this tractor didnt used to do this and it has to be something simple, if i can just figure out what
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
