The pump metering valve may be sticking. When at high idle does the engine want to under run low idle speed, or even die on deceleration? If so the valve is sticking. May also be the retainer ring inside the pump failing, plugging the return line check valve in the bottom of the fuel tank. Test by letting fuel leak out of the housing with the timing cover screws loose, if it revs OK then the pump needs serviced before the retainer pins shear off, locking the head/rotor and breaking the drive shaft.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
