Re: 1948 super a brakes
Posted by sogojog2 on July 28, 2014 at 16:08:33 from (174.21.130.177):
In Reply to: 1948 super a brakes posted by sony224422 on July 28, 2014 at 09:28:48:
Maybe you might be able to use brake clean on your brake pads drums. Just athought, i dont't know. If you you can get to em :idea:
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
