I can not see a good reason for it not to lock in the shut off position unless the rod is totally out of adjustment. You do realize the lever does not lock in the engaged position, right. The lever just floats. I have seen some people adjust the linkage so lever locks when engaged and in that case the lever will be totally out of wack in the disengaged position. It should have about half inch or 5/8th inch of tension in shut off. In other words, you feel the internal brake compress the springs inside when the pawl is that far from the notch toward disengage. Also, nice snap when going over center to engage.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
