Posted by famousfather on July 06, 2014 at 15:50:57 from (75.133.49.203):
In Reply to: Re: Stuck In Reverse posted by ken house on July 06, 2014 at 14:52:36:
Hey Ken, thanks for the idea. Just got done trying it but it didn't work. Jacked up one rear wheel and the wheel started to gradually move a bit as the pressure was relieved and the wheel came off of the ground. Tried to move the shifter which feels like neutral but trans is in reverse and the shifter only moves into 2nd or 3rd...when I let the clutch out when in 2nd or 3rd the tractor won't move forward and wants to stall. Doesn't matter where the T/A is placed, either. Tried the other wheel with the same negative results. Thanks again for your timely response.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
