Rented a "front end service set" from Advance Auto and used the pitman arm puller and tie rod end spreader to pull the lever up off the shaft without having to remove the steering wheel (simply needed a way to pull straight UP on that lever). Just need to be more careful of the threads in the future, I had to clean them up with a die. Heated cherry red the evening before and sprayed PB blaster on it after so that may have helped with the pull as it didn't fight too hard, but still definitely needed the puller tools.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
