I agree with 80 psi compression is low. Check your plug wires and also the condition of your distributor cap. Also check your points, they should not be burnt or corroded and set to the proper gap. Another thing that you could check is your valve to rocker arm clearances. They do wear and need to be adjusted over time and often overlooked. For what its worth, I had an M that I could not get to run right no matter what I did. It turned out to have a cracked head and a bad head gasket. After fixing it, it starts and runs perfect. M's where bad about developing cracked heads. Funny thing about mine was, very little water would disappear from cooling system. Non the less though, there would be a few drops of antifreeze in the bottom of oil pan. To check that on yours, just let the tractor sit for a few days and then loosen the oil drain plug just to the point that it will drip (don't take it out) and if antifreeze drips out you likely have a cracked head or bad head gasket. This creates compression problems, and moisture in the combustion chamber fouls the spark plugs.
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
