The specs for amperage draw is a no load spec used for testing the starter. The loaded draw will be much higher. Some starter specs give an amperage draw for a locked starter but the Delco Remy chart did not have that information for the starter numbers I looked at.
This post was edited by Owen Aaland at 07:41:34 06/13/14.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
