Removing the sleeves will likely be difficult. I have removed a lot of them using a 20 ton hydraulic press and several have taken almost the full 20 ton to get them to pop loose. You may want to consider testing to see if the block will hold water and if you don't see any water leaking past the O-ring and out the bottom of the sleeve, then you would not HAVE to remove the sleeves and replace the O-rings.
Here is a picture showing the device I made to hold F20 engine blocks upside down in my press without removing the head studs for the purpose of pressing out the sleeves.
To hone the cylinders you need what is known as a cylinder hone. It has 3 spring loaded arms with a fine grit stone attached to the end of each. You put it in a drill and run it at a slow speed while also moving the drill up and down to put in the "cross hatch" pattern.
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
