Posted by MAH on May 31, 2014 at 05:27:49 from (71.83.74.137):
Hello, I have international 454 that has always cranked and run real well. I started getting diesel in the crankcase so I took it off and had seals put in the pump. I put the pump back on and now it won't start. I talked to someone and they said might need to take pump off and turn pump revolution. Also, the guy that worked on my pump said that the two lines one from filter and the other on top of pump. He said that you need to make sure you put the bolts that hold the lines are put in the same place they come out. One of the bolts has a bigger hole up through the bottom than the other. Can someone tell me which one goes where? In case I have them mixed up.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
