Posted by mkirsch on May 20, 2014 at 12:51:23 from (65.199.189.6):
In Reply to: 240 Engine swap posted by Mo in NE Tx on May 18, 2014 at 15:51:18:
My guess is he's makin' a puller out of it.
All you really need is the governor off a 240 to get the RPMs. The main difference internally in the engine is a slightly smaller combustion chamber in the head on the 240.
If your Super C engine is strong with good compression, and you're really only after the power for pulling, go for the governor.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
