if this is a good running tractor with constant good oil pressure,
I'd just leave it be. Breaking or stripping a worn rod cap bolt to just change those clips will ruin your day.
With that said, when I buy a tractor, especially a Farmall where it is so easy.....and I have the oil pan off for cleanup....
dunno..can't resist I guess.
At a minimum, I'll put new rod bearings in (same size that are in there) Then plane the oil pump cover plate, and put a new gasket in it.
Peace of mind for under a hundred bucks.
(And every time, I didn't...I regretted it later)
old parts get labeled and saved. Got an engine right now that is not worth a single dime. But with my old 'not too bad' bearings and engine parts collection, it's going together with all used parts. Correct...no, will it run and be useable..yes
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
