Re: 300 utility hydraulics dumb question
Posted by mkirsch on May 14, 2014 at 05:24:52 from (65.199.189.6):
In Reply to: 300 utility hydraulics dumb question posted by glacier-tractor on May 13, 2014 at 05:43:14:
Here's one of those "teach a man to fish" moments.
partstore.caseih.com has most of the parts books for most IH equipment online and available for the "common man" to reference.
Here's a diagram clearly showing the inner line from the pump running to the lower port on the hydraulic block:
http://partstore.caseih.com/us/LambWebsterNorthJava/parts-search.html#epc::mr59117ar845051
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
