Posted by pete 23 on May 07, 2014 at 17:58:20 from (74.33.89.148):
In Reply to: 656 FYI posted by DV on May 06, 2014 at 06:56:55:
Not trying to pester you here, but the orfice should be quite easy to see. It is a very small hole down inside of a little larger hole and leads to the inside of the piston and out the other side.. This allows fluid to escape from one side of piston too the other side other wise hydraulic lock occurs and the piston cannot move. Normally when a hitch gives this problem the orfice has a tiny bit of junk plugging it. As far as the spring, I mean the one that is inside the piston. It is a crimped assembly so it cannot be taken apart but some times that spring breaks and if you push down on the pin end of the piston you can tell a difference from a new piston. I have not seen that happen on a 656 but was not uncommon on older tractors.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
