As far as I am concerned leaving a tractor parked in gear is a bad habit. The reason is I remember catching my 5 year old climbing up on the H and pulled the switch on and pushed the starter button. I was 50 ft. away and when that tractor started I think I made the 50 ft. in 3 steps. After that every tractor gets the brake set and shut off in neutral. That boy is now 43 years old.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
