It sounds like one of the change over valves is stuck open. That will cause that. Ours will do that some times. If you take the tappet cover off and tap that valve it will probably help. Give it an oil change seems to help with that. If you could go work it hard like on a plow for a day or so it would probably clear it up. They need to run daily or those change over valves will stick like that. When we used ours to feed cows every day it would start fine even at -20. Might even be the only thing that did start.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
