You can also find out what you currently have on the tractor.
Stick a ruler through the gap between the rim and the hub, and align the end with the edge of the rim bead on the inside. Sight a measurement on the outside edge. A 9" rim should measure between 9.25" and 9.5". It measures 9" inside.
You want the vertical surface that the bead of the tire pushes against, not the lip.
Or you could make yourself a giant set of calipers out of cardboard.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
