I also stop my MD with the clutch just before it is about to roll to a stop. The flywheel teeth are worn a bit in the usual place. By stopping it in a different place, the starter kicks in better and doesn't cause more wear in the same place. Been doing this for over 40 years and have not had to remove the ring gear or starter. Al
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
