Posted by rustred on April 26, 2014 at 17:33:15 from (74.214.152.80):
In Reply to: Crank Shaft Bearing posted by Dave8N in Pa on April 26, 2014 at 09:53:52:
you should specify what you are working on or referring to before the confusion get too big. brgs.- yes seals- usually no, unless you have a rope seal. if you are referring to an old 390 ford then the answers are yes to both.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
