Posted by athol carr on April 24, 2014 at 19:19:01 from (115.188.3.223):
In Reply to: Waukeshaw posted by James Williams on April 24, 2014 at 05:39:42:
The engine is a 113 cub inch Waukesa Flat-head (or L-Head, i.e. side valve) model FL engine. The parts numbers for most of the FL engine are the same as the Fuller & Johnson BD-1 engine that was built for IHC to put on the model 20 and 21 Harvester Threshers. The parts that are different are the head (the harvester engine had the radiator over the flywheel with the fan driven by belt off the flywheel) and the front cover on the timing, governor and magneto drive gears. This engine was fitted to the first 2500 F-12 tractors except 10 at about number FS-600 to FS-609 where IHC tried their own new 113 overhead valve engine which became the standard engine for the F-12 and the other 12 series tractors. There was also a small number of F-12 tractors fitted with a Waukesa engine with replaceable sleeves
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
