"My question is what does the 3rd brush do and do I need it with a regulator"
The physical location of the third brush regulates the rate of charge. The closer it is to the fixed brush the more charge, the further away the less charge. Some 3 brush are adjustable (can set third brush closer or further away from fixed brush)
Early 3 brush gennys were seen often when a full fledged automatic Voltage Regulator WAS NOT USED but instead only a simple manual Low or High charge selector light switch.
However, in later years they still used some 3 brush gennys even when they went to a full fledged automatic Voltage Regulator. Later they went to 2 brush gennys and full fledged Voltage Regulators.
COMMON PROBLEMS are the brushes are worn down too short,,,,,,,,the fields may be open or shorted out,,,,,,,,,,,,The splice may be open or shorted where the 2 fields connect together,,,,,,,,,the armature may be shorted to case. A physical inspection and an ohm meter can test for much of that while a growler may be necessary for more precise accurate armatures testing.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
