Posted by pete 23 on April 19, 2014 at 19:44:40 from (74.33.94.238):
In Reply to: 504 pto main drive gear posted by teachingscience on April 19, 2014 at 06:18:06:
Notice the early serial number tractors did not use a wedge. I believe on those the shaft was longer and came closer to going through the gear or the gear was slightly different. Some one may have done some changing over the years to try to keep that gear tight. I never saw one get loose that used the wedge. The older ones came loose and that is why they went to the wedge.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
