first step is compression test, that will tell you if you have enough vacuum to draw the gas from the carburetor. it will also tell you if you have stuck or burnt valves. it will basically tell you the engines condition. you should have around 125 psi pretty much straight across with only 10 percent variation. make sure you have the main needle valve open , about 4 turns from its seated position and the mixture screw 1 turn. its also possible you can have a plugged orfice in the carb since it was sitting and you have not soaked it. pull the plug from carb bottom and make sure you have gas flow. it will run.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
